AC Problems
Old Jul 9, 2007 | 07:09 PM
KY95Z28's Avatar
AC Problems
Today I started my car for the first time in a few months. I decided to turn on the AC and white smoke started coming from my vents. I then popped the hood and smoke was coming from the compressor along with a crackling sound......kinda like it was on fire.
I'm sure the compressor is shot, but I'm trying to fiqure out what went wrong, it made no wierd noises when I turned it on. Anyhow what parts should be replaced along with the compressor?
Thanks,
Old Jul 9, 2007 | 08:15 PM
CheshireCat's Avatar
I've never seen a compressor go up like you describe. Hopefully the smoke you describe coming from your vents was just the escaping R134 from the compressor blowing...
Hopefully only the compressor failed, but I'd replace the expansion valve, and possibly the accumulator/dryer while you're at it...
good luck.
Old Jun 2, 2008 | 10:10 PM
94lt1camaro's Avatar
My car just did the same thing as the orginal first post what end up being the issue.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
