AC Oil Filter part numbers change?
Old Jan 23, 2003 | 04:36 PM
  #16
Allen66's Avatar
Neither Wal-Mart nor Kmart sell AC anymore. If KMART still did, you could probably stock up on them real cheap when they finally go under.
Somebody actually said the Wal Mart filters weren't bad. I'd be scared of them myself, at least on something I cared about.
Old Jan 23, 2003 | 04:48 PM
  #17
Buttercup's Avatar
How would you lose pressure with a larger filter If you do not add enough oil than a larger capacity filter will increase the chance of uncovering the pickup, that would be bad. You do need to add more oil to the system when using a larger filter, but that's one of the benefits. It takes some pretty nasty oil to clog a filter, but if it is that bad the larger filter will clog later than a smaller one (if there filtering media's surface area corresponds to case size, like the PF35 and PF25 do)
Old Jan 23, 2003 | 06:38 PM
  #18
Patman's Avatar
The Walmart's Supertech filter is made by Champion Labs, it's a very high quality filter for the money! Champion Labs also makes the K&N, Mobil 1, Bosch Premium, STP and they used to make the Ultraguard Gold.
Supertech is a 20 micron filter.
Old Jan 24, 2003 | 08:20 AM
  #19
93zder's Avatar
Walmart oil
I wonder if Walmart's oil is any good - i think it's called Tech 2000? Anyone tried it?
Old Jan 24, 2003 | 09:08 AM
  #20
Patman's Avatar
Walmart's oil is made by a subsidiary of Quaker State and I've seen a virgin oil analysis on it (new oil) and it doesn't look too bad for the money.
If I were going with a conventional oil though I'd spend a few extra pennies and go for Castrol GTX though. No sense running the Walmart oil just to save $1.50 at oil change time.
Old Jan 24, 2003 | 11:22 AM
  #21
93zder's Avatar
I agree. But i must admit i bought some Esso Extra 5W30 @ $5 for 5L for my winter car - sounded like too much of a bargain to pass up!
Old Jan 24, 2003 | 03:57 PM
  #22
Patman's Avatar
I just picked up a 4L jug of Castrol GTX last week at Walmart for $5! That's $3.25 in US dollars! This oil is going in my sister's car (I'm going to run two intervals with GTX then two intervals with Syntec and compare the oil analysis results)
Old Jan 24, 2003 | 05:16 PM
  #23
Allen66's Avatar
Who makes the Valvoline filters? We had our oil changed at a Valvoline quick lube center while on vacation last summer. The oil came out looking far cleaner than the Quaker State/AC filter combo I normally use.
Old Jan 24, 2003 | 05:38 PM
  #24
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
the Pf25 and things like it have more than enough filtering capacity even for long oil change intervals... people only want larger filters for the increase in oil capacity... why more oil is good i dunno the car already holds more than enough to keep everything covered... btw i ONLY use mobil 1 synthetic 5w-30 and ac filters... i was considering a "k&n" oil filter that they have on their website but its almost 15 bucks with shipping... sounds like a waste to me...
Old Jan 25, 2003 | 06:17 AM
  #25
Patman's Avatar
Champion labs makes the Valvoline as well, but I'm not sure of the specs.
Also, the reason you want more oil is because more oil means less stress overall on the oil. I run 5.5 qts in my LT1 with the long filter. Also, a longer filter holds more dirt and provides less restriction to oil flow. There is no reason NOT to run a longer oil filter.
Here are two links that I'm aware of that I believe both have the K&Ns under $10 with free shipping:
http://www.treadstar.com/cgi-bin/tru...t/indexkn.html
http://www.martelbros.com/cgi-bin/st...ore=direct.KNN
Old Jan 25, 2003 | 07:41 AM
  #26
93zder's Avatar
The deals just keep getting better! Oh well, i think the Esso should be sufficient - have you seen any analysis on this stuff?
Old Jan 25, 2003 | 02:25 PM
  #27
Patman's Avatar
Nope, since it's only available up here, and not many people in Ontario seem to do oil analysis, I haven't seen any results on it.
Old Jan 26, 2003 | 12:04 AM
  #28
Allen66's Avatar
I meant to say that was in my wife's car. I run Penn. Synthetic in my car, and NOBODY but me changes the oil or anything else.
Champion filters must be good. Like I said, the oil in my wife's car looked much cleaner than it ever has after I changed it.
Also, I went in another AutoZone looking for a PF25. They had the display that said the PF 454 is replacing the PF 25. I just don't understand it.
HectorM52
Jul 30, 2017 11:46 AM
parkers Z28
Mar 11, 2016 08:14 PM
Jul 4, 2005 05:00 PM
97 RedSS
Jun 10, 2003 07:58 PM
