About to give up! MISFIRE
Well my car is in the shop and it just had all new wires and plugs installed and they said that should fix the problem, well they took it out and it still popped a misfire code in cylinder 4, so he took it back in fooled around with it checked it again and then drove it it still misfires. WEll we are about outta options cuz the opti was replaced about 1500 miles ago. NE help would be greatly appreciated. Thanks
Vince
Vince
Re: About to give up! MISFIRE
Well, since you said the opti, spark plugs, and wires are fine, the nex thing to check for would be leaky/sticking injectors. My friend just went through this on his 2001 Silverado, had a slight misfire. So he swapped coil packed and did plugs. Come to find out, he needed a new injector and hasn't ahd a problem since.
zajones
Jul 30, 2015 02:18 PM
