a4 dissassembly question
Old Jan 23, 2003 | 03:50 PM
67LT1Bird's Avatar
In disassembling my transmission, I have found that the 1-2 accumulator's piston was turned upside down from my factory unit repair diagram with 2 springs stuck inside the accumulator assembly.
Was this some kind of shift kit, or did some jacka$$ screw up the assembly process. Inside the accumulator assembly, the top area is slightly chewed up from the larger of the two springs. The spring colors are green for the larger diameter one and white for the smaller/stiffer spring. I am figuring that this was done wrong because I have seen no pictures of such a setup, but I have never worked with a shift kit before. Am I right?
Jon
Old Jan 24, 2003 | 04:33 PM
67LT1Bird's Avatar
Lightbulb
Please! Anyone?
Old Jan 25, 2003 | 07:28 AM
Ken95Z28's Avatar
Here is the link to the transgo instructions.
Transgo Shift Kit Instructions
This is how it should go according to my ATSG manual.
1-2 Accumulator
Old Jan 25, 2003 | 11:26 AM
67LT1Bird's Avatar
Ken,
Thanks alot for the pics. http://ken.lowrance.com/images/Transgo/1-2Accum.jpg is what the factory manual shows also. When I disassembled mine, the piston was flipped and two springs were on the opposite side of where they should have been, but the reference was correct relative to the piston. I sure wonder whether this is what led to my forward clutch or something going out. Damn *******!
Jon
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
