97 Camaro to OBD1
Old Jun 26, 2013 | 02:46 PM
BLWNLT1's Avatar
97 Camaro to OBD1
I have an engine with double roller timing chain, which did away with the crank sensor gear. I have an 95 pcm with LT1 edit cable and software. What all needs to be done to make this work?
Old Jun 26, 2013 | 02:53 PM
Re: 97 Camaro to OBD1
Nothing, with regard to the crank (CKP) sensor. It was added in 96/97 for OBD-II misfire detection. It has no relevance at all to the way the engine runs. 93-95 do not have the CKP sensor.
You will need a knock sensor from the 93-95 cars (4,000 ohm). Your 97 has a 100,000 ohm knock sensor. You can also keep the 97 KS and have a resistor added to the 95 PCM.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
CARiD
Jan 14, 2015 04:00 AM
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
