97 camaro LT1 misfires
Old Apr 2, 2006 | 04:17 PM
  #16
moparman's Avatar
Re: 97 camaro LT1 misfires
Autozone will pull the code(s). Free. Post the code numbers.
Old Apr 3, 2006 | 07:45 AM
  #17
JimboManJones's Avatar
Will a bad injector cause a misfire but no codes? Plugs/wires will defintely cause a code if they go bad right?
Old Apr 4, 2006 | 05:22 PM
  #18
AndyCLT1's Avatar
Not sure about OBD II cars, but my '94 doesn't throw a code for a burnt plug wire.
Andy
Old Apr 4, 2006 | 05:33 PM
  #19
OBD-II does set codes for misfires. OBD-I does not.
Get the 97 scanned with a scanner that can access the "GM Enhanced Parameters". With that scanner, you can pull up the misfire count, by individual cylinder. That will tell you if its a single cylinder, cross-firing between two cylinders, a truely "random" misfire, etc. Its going to be a lot easier to find the problem if you know exactly which cylinder it is. The cost of a good scan will be less than throwing the cost of a new Opti at it.
AdsoYo
May 2, 2018 03:21 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
Jul 4, 2005 05:00 PM
Burn_Out
Aug 18, 2002 08:49 AM
