96z28 convert LT1 ignition to LS1
Old Jun 26, 2006 | 09:17 AM
cleangene's Avatar
is it possible to convert the old style LT1 ignition to the newer type LS1, if so what are the problems and the cost. I hate the LT1 igniton, its almost impossible to work on...
Old Jun 26, 2006 | 10:22 AM
Re: 96z28 convert LT1 ignition to LS1
You can get 1/2-way there.
Purchase the LTCC conversion from Bailey Engineering. That system uses only the optical signals from the Opti to feed a black box, that drive 8 LS1 coils in direct fire mode. By removing the high voltage functions from the Opti, it appears to extend its life and reliability. I've been running a similar setup for 6 years now.
http://www.gmhightechperformance.com...htp_optispark/
http://www.bailey-eng.com/
There is a similar system from Delteq that uses a black box to drive the Northstart V8 IC Module and a 4-coil pack setup in waste-spark mode.
http://www.delteq.com/
Old Jun 26, 2006 | 10:42 AM
BT283's Avatar
It seems like you could almost put that together yourself for alot cheaper
DirtyDaveW
Dec 1, 2016 05:37 PM
Ari G
Dec 11, 2014 03:21 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
