96 z28 lt1 tuner
Old Jul 12, 2013 | 09:00 PM
Old lead Foot's Avatar
96 z28 lt1 tuner
THis is all new to me. Here Goes. I just bought a 96 z28 convertible.
I installed a K&N induction and it has dual flowthru exhaust system. I would like to increase the HP. with either a chip or a system programer. what are the pros and cons of each and what do you suggest? I haven't had much luck
searching for this hardware. Thank-you in advance.
Best Regards
Old lead Foot
Old Jul 12, 2013 | 09:54 PM
slick1hunting's Avatar
very little gains in a chip or programmer. Better to get a dynotune. If dynotune isnt feesable then a mail order or email tune is the next best especially if you can give tuner feedback with datalogs.
Posted from Camaroz28.com App for Android
Old Jul 13, 2013 | 01:52 AM
1FST4GEN's Avatar
Re: 96 z28 lt1 tuner
I've learned either go with pcmforless or madz28 tunes. Pcmforless is a mail order and madz28 can build and email your tune for you to flash to your car. Nice thing is it allows you to customize it and you can also provide datalogs for adjustment/correction
Old Jul 13, 2013 | 11:16 AM
Just to clarify - there is no "removable" chip in your 1996 PCM. It has to be flash programmed. The "chips" you see on ebay are all scams, usually consisting of a 10-cent resistor in a small plastic case that you wire into your IAT sensor or TPS sensor. They do absolutely nothing. The Hypertech Power Programmer has been shown to lose HP on even a stock setup, unless you also get the 160*F t'stat and use the programmer to reprogram the fan on/off temps.
As noted above, mail order is your best bet.
Old Jul 14, 2013 | 06:52 AM
plattted's Avatar
How about just changing the rocker arms to 1.6 and changing the valve springs to a better quality?
Old Jul 17, 2013 | 05:55 PM
my94blackz's Avatar
Lt1s run pig rich factory, so the only way to cure this problem is a dyno tune.
If its an auto it would be worth taking it to a good lt1 tuner or a tuner that cares and have it dyno tuned and street tuned.
Old Jul 17, 2013 | 07:13 PM
smallblockhero58's Avatar
yeah im with everyone dyno tune, i looked everywhere for that answer- luckily i have Hawks third gen 30 min from the house cant wait to get my dyno tuned
Old Jul 18, 2013 | 08:18 PM
my94blackz's Avatar
Or you got Tick just a little further up the road.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
cmdeshon
Jan 4, 2015 11:15 AM
Jul 4, 2005 05:00 PM
tubby
Oct 13, 2003 09:16 AM
Evilfrog
Aug 7, 2002 11:36 PM
