96 Z28 dies after running for a little while
Old Oct 9, 2008 | 02:45 PM
cory's Avatar
crank it up it runs fine , but after around 15 minutes it dies, will not crank right away but let it sit and it cranks right back up and does it all over again.
anyone else ever had this problem?????
no codes are getting set , and i have no idea what the problem is.
Old Oct 9, 2008 | 03:10 PM
bombebomb's Avatar
Maybe a sensor (for lack of better terminology) is getting heat soaked causeing it to die.
Old Oct 10, 2008 | 07:03 AM
cory's Avatar
i was thinking the same thing , just didnt know what sensor to start with. lol
Old Oct 13, 2008 | 04:03 AM
SS44Camaro's Avatar
https://www.camaroz28.com/forums/sho...d.php?t=641184
i think you guys are in the same boat.
Old Oct 14, 2008 | 07:55 AM
joshmullins8's Avatar
It may be the optispark distributor, there is a kit from MSD that Jegs sells it comes with MSD Optispark Distributor,MSD 6AL Igniton Box,MSD Blaster Coil,MSD Installation Wiring Harness,MSD Custom-Fit Super Conductor Spark Plug Wire for $989.99, i just got one, I love it.
But I just read someone elses post about the same problem and everyone else was also the opti but idk
Old Oct 14, 2008 | 08:46 AM
SS44Camaro's Avatar
thats great if you have the money but not nessisary if you dont. stock ignition is fine on a stock or bolt on car. just dont get a cheap *** opti. get msd or gm. if you go cheap go autozone that way when it goes out its free to replace.
Old Oct 14, 2008 | 11:33 AM
cory's Avatar
new GMP opti dont have 200 miles on it. i will check the ICM
Old Oct 14, 2008 | 11:36 AM
SS44Camaro's Avatar
you can get the icm tested at autozone. new opti, but what about the cap?
Old Oct 16, 2008 | 07:01 AM
cory's Avatar
it was all bought new complete opti
Old Oct 16, 2008 | 09:28 AM
SS44Camaro's Avatar
does your engine light come on? if so get it scanned
Old Oct 16, 2008 | 02:06 PM
The two parts most vulnerable to heat soak are the IC Module and the optical electronics in the Opti. Was the problem there BEFORE you installed the new Opti? Have you checked the accuracy of the coolant temp sensor in the water pump housing?
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
