MSD P/N 32139 quick question
Old Oct 15, 2008 | 10:52 PM
camarozz95's Avatar
I want to order these, but I am a little confused I heard that this set comes with the opti ends pre-installed and the spark plug boot and terminal you have to install yourself is this true? My taylors on my OTVC kit i got had the opti ends I had to crimp myself, and they need to be replaced and I do not want the taylors again. I would much prefer the opti ends to be pre-installed. Thanks for the help.
Old Oct 16, 2008 | 09:24 AM
brianswimmer23's Avatar
dont go with msd go with OEM AC DELCO and then you wouldnt have to worry about a thing as far as having to put anything together.
Old Oct 16, 2008 | 09:52 AM
camarozz95's Avatar
Well I have the Over the valve cover kit but I want to change the wires. I'm pretty sure OEM Delcos won't work.
Old Oct 16, 2008 | 10:18 AM
bombebomb's Avatar
The msd wires I had were all premade, precut, both ends on them.
It appears from the jegs photo however, that yours do not have one of the ends on them. My opti boots were straight, while them are bent, asuming them are the opti boots, then from the picture it shows the spark plug boot needing to be attached.
Old Oct 16, 2008 | 10:44 AM
96flame's Avatar
The msd cut to fit come with the opti end on as you have stated. They worked great for OTVC wire when I used them. It comes with a crimping tool for the vise which works good too.
Old Oct 16, 2008 | 03:32 PM
camarozz95's Avatar
Thanks! just the answer I was looking for.
RUENUF
Mar 13, 2016 03:39 PM
Airplanedoc
Parts Wanted
Apr 18, 2015 04:22 AM
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
