96 trans am passenger side exhaust manifold removal
Old Oct 5, 2014 | 01:52 PM
96fire/ta's Avatar
I just recently bought a 1996 Pontiac trans am lt1 automatic. all stock I bought from an older lady, only 110k miles. Has an exhaust leak from the passenger side manifold. So I bought the gaskets an took off the alternator I got the front 3 bolts out but cannot get to the back 3 at all. From underneath it looks like I'd have to pull the exhaust pipe running to the driver side manifold to get my hand in. Any ideas, tips or tricks would be greatly appreciated. Thanks
Old Oct 5, 2014 | 02:34 PM
Re: 96 trans am passenger side exhaust manifold removal
Your going to have to unbolt the Y-pipe to allow the manifold to move away from the head, so you can clean the old gasket off, etc. Most likely you will snap a stud or two when unbolting the Y-pipe. Use lots of PB Blaster.
Old Oct 5, 2014 | 02:37 PM
People with skinny arms can get the manifold to head bolts from the top.
Old Oct 7, 2014 | 08:01 PM
ACE1252's Avatar
Hehe, I'm one of those people, but I said to heck with it. I think from the bottom is the way to go, but the y-pipe will be a pain if it's never been removed.
I snapped some studs myself when I had the stock setup. Some of that was from when I got a decent air tank and air tools in my garage and said **** this. You have to be careful with that too as rounding a nut or stud will make for a even worse day.
Old Oct 10, 2014 | 08:41 AM
raroz28's Avatar
it's worth it to just do headers.
I'd pay $200 for a used set before I bloodied my hands up dealing with the factory setup.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Chris Anderson
Jan 27, 2015 08:30 AM
markaubuchon
Jan 14, 2015 01:48 AM
spearous
Jan 12, 2015 11:03 AM
Jul 4, 2005 05:00 PM
