96 LT1 sounds like it has a cam, 93 LT1 doesnt?
I took both exhausts off my car today and I just got a new 96 Lt1 formula, I turn the formula on (after taking off stock exhaust) just running after the ypipe and it sounds amazing has a lope to it and makes that pop corn noise of a cam, my 93 car is loud but doesnt have that same pop corn noise/lope. Are the cam profiels that different from 93 - 96? Im almost positive this car doesnt have a cam in it.
Re: 96 LT1 sounds like it has a cam, 93 LT1 doesnt?
Originally Posted by 1SlowFormula
It could be anything from tune to the fact that the 96 is an M6 and has a higher idle...
Are the cats stock on it, or are there even cats on it? And a higher idle would definetely make it sound like it had less of a cam than a lower idle would.
There are cats on it, it idels at around 900 rpm when starting it cold, just like hte 93 car. Would a dual cat setup really make that much of a difference? Its not any huge lope but its definitly different from the other car. I dont know why someone would just put a cam in it, everything else was stock, except the air box.
96 also has dual cats vs single on the 93. however if the car sounds cammed, it probably is. Alot of people will de-mod their cars prior to selling them, and most people arent going to go that far cause chances are it wont get noticed.
Hows the 96 throw down? I alway thought people were underdogging the LT1's saying they were slow and ****, and I always thought mine felt fast as ****.. I did noticed that it had a slightly choppy idle, but thought it was b/c of my exhaust.. But I went down and dominated a 96z28 m6 with 4:10's from a dig. IDK if my car is just a freak, or if it was cammed.... Sux having a used car.
Here's what my '93 sounds like with no exhaust. Well..if you consider a Bullet exhaust..
http://videos.streetfire.net/search/...69EADCE16A.htm
1993-1995 Y-body, F-body: 202/207 0.450/0.460 lift 116 LSA
1996 Y-body, 1996-1997 F-body: 200/207 0.447/0.459 lift 117 LSA
they should sound about the same... the lower idleing car should sound like it has a bigger cam...
oldschool
Feb 9, 2016 09:21 PM
