[edit] these pacesetter LTs
Ok, i use the board alot to decide what should be a good upgrade, well i decided the pacesetter LTs would be good since so many people have them and suggest them. ALso talk about how they arent too bad to put in.. well i am callin BS on that. For one big reason the driver side the second bolt, how the HELL are you suppose to put a bolt in when the pipe bends right infront of it wtf???
Re: F*&K these pacesetter LTs
You gotta put that one in first. If you tightened up the other ones, just loosen them up so you can pull the header away from the head a little bit and it should go through. I repeat, THAT ONE GOES IN FIRST.
If you f'd up like I did, I got the 12-pts which I could not use the open end of the wrench. I then took a die-grinder and "clearanced" the sides of the wrench and basically grinded it down flat.
Hope it helps.
Ps~ I did the exact same thing you did.
Hope it helps.
yea i had to pull the whole header back off.. and about the only way i would be able to get it through is with a hammer, there is no way to possible get a 1" bolt through,unless i cut the pipe and bent it out of the way. or the only other option, which i plan on doing tommorrow, drilling the hole out so i can angle the bolt enough to get it through
The ones i used were 1" too. 12 point Breslin bolts. I couldnt get a socket on most of them, so the torque wrench was pretty useless, so i had to tighten them with the little 3/8ths wrench. 30ft-lbs with a little tiny *** wrench kills your hands.
WobblySausage
Oct 7, 2015 02:44 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
