95z28
Old Jan 24, 2016 | 05:21 AM
muddjar39's Avatar
95z28
My Z throws the check engine light and when I turn it off its hard to start.Help
Old Jan 24, 2016 | 10:19 AM
Re: 95z28
Scan it for codes. Hard to do on a 95, because of the unique combination of an OBD-1 PCM and an OBD-2 "style" 16-pin ALDL connector. If you have access to an OBD-1 scanner, you can jumper the 12-pin connector, as shown by Shoebox:
http://shbox.com/1/xraycable.jpg
Even better, download the free Scan9495 software, get a cable from Red Devil River or ALDLCables (or build your own).
https://www.camaroz28.com/forums/com...95-lt1-874306/
Extended cranking can be due to several reasons, and the code may show something like a faulty coolant temp sensor. Extended cranking can also be due to rapid loss of fuel pump prime pressure, and you need to check the pressure with a fuel pressure test gauge.
bond2
Jan 21, 2016 09:26 PM
Hawkman978
Jan 20, 2016 12:48 PM
blac94Z
Jan 15, 2016 11:21 AM
NewsBot
Jan 13, 2016 07:00 PM
350350
Jan 7, 2016 10:16 PM
