95 z28 starts misfires then stalls
Old Nov 16, 2011 | 10:45 PM
duker's Avatar
Exclamation 95 z28 starts misfires then stalls
so recently i accidentally drove through a puddle, car backfired, stalled and wouldnt start afterwards. i replaced the distributor opti not the cap and rotor and put ngk plugs ignition coil as well as the module and finally got it running. when i crank it , it takes a good few tries for it to start will idle high and feels like huge misfire as well as some smoke coming from the intake and exhaust then it stumbles and stalls since ive been trying to get it started there is no coolant no trans fluid due to the radiator being taken out also its open headers right now.. can someone give me a good description on what to do as well as some diagnostic aid.
Old Nov 17, 2011 | 05:36 AM
TedH's Avatar
Re: 95 z28 starts misfires then stalls
Welcome. My first suggestion is to try the tech forums.
Old Nov 17, 2011 | 07:59 PM
CamaroBoy96Z28's Avatar
If you're confident you have spark, I would check fuel pressure and make sure you're getting fuel to the rail. It would be coincidental that a fuel pump went when getting the opti wet, but you rule something out.
Old Nov 18, 2011 | 12:27 PM
duker's Avatar
i found out the maf is bad had open circuit no ground. however heard if you unplug maf goes in to fail safe mode, did that and smoke is coming from intake and exhaust at same time...would anybody think its timing chain or spark timing? and my fuel pump is always on i can hear it.
Old Nov 18, 2011 | 09:45 PM
ACE1252's Avatar
Did you drive through a puddle the size and depth of a lake? Puddles should not do that to an LT1.
You say you replaced the opti, but not the cap and rotor....worded like that, to me, means that you replaced nothing. So...I'm guessing you replaced something connected with the opti system...just not sure what. What brand component did you use?
Did you pull the intake for any reason? What was the need in taking the radiator out?
Old Nov 20, 2011 | 12:48 PM
duker seems to have trouble finding this thread. Let's do a "TTT" so he hopefully can find it, and doesn't keep posting the same question on Advanced Tech.
Noenav
Mar 1, 2019 07:38 AM
AdsoYo
May 2, 2018 03:21 AM
PCLZ28
Dec 24, 2015 05:19 PM
thenewkid
Nov 27, 2014 09:41 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
