95 z28 air intake elbow
Old Jun 22, 2013 | 10:51 PM
ChevyBoy6155's Avatar
Exclamation 95 z28 air intake elbow
need a need Ai Elbow asap for my 95 z28 Lt1..
GM dealer said they are discontinued. i found some online
(trickflow,jegs,1le) but they dont have the long "silencer" tube at the bottom..
>does it effect anything if i get a new elbow without one????
if not, witch does anybody recommend the best????
Old Jun 23, 2013 | 09:03 AM
Re: 95 z28 air intake elbow
Since this isn't an "exhaust" question, let's move this thread to "LT1 Based Engine Tech".
There is no problem with deleting the silencer tube. In fact the stock intake elbow for the cars with the "1LE" option did not have the silencer tube.
Old Jun 23, 2013 | 09:30 AM
thank you for your time.. would it make any difference to use a plastic or aluminum elbow??
Old Jun 23, 2013 | 09:35 AM
I thought the 1LE rubber elbow was still available. That would be the best replacement. The absence of the silencer tube makes it easier to install, and the rubber is going to resist heat transfer from the engine compartment better than metal. Aluminum is a great heat conductor.
Check this part number, courtesy of Shoebox:
1995-1997 1LE intake elbow - (for vented opti)
PN 25147187
Old Jun 23, 2013 | 10:07 AM
PN 25147187
Still a good part number and available. It is actually a better piece than the original that has the silencer.
Old Jun 23, 2013 | 11:36 AM
>> thank you guys for the info.. will this part do the trick?
-> Chevrolet Performance LT1 Air Inlet Elbows 25147210 - Free Shipping on Orders Over $99 at Summit Racing
Old Jun 23, 2013 | 11:49 AM
Originally Posted by ChevyBoy6155
No, that is the wrong one for a 95. It has no hole for the vented opti air inlet. You need the one with the part number Injuneer and I posted.
Old Jun 23, 2013 | 11:58 AM
i cant seem to find it. do you have a link for the best place to order it from?
Old Jun 23, 2013 | 12:05 PM
There are recommendations on my website for buying GM parts. This GM part is often resold by other shops on the internet. You might search to see if you can get a better price somewhere.
thenewkid
Nov 27, 2014 09:41 AM
RedLineRev
Jan 23, 2003 03:51 PM
slothgrant
Aug 22, 2002 03:01 PM
turbo_Z
Aug 19, 2002 10:50 PM
30thZ286speed
Aug 3, 2002 04:54 AM
