95 Z Obd1
My 95 Z has obd 1 with an obd 2 connector and I want to know if antone knows what pins I use to jump so I can get the codeds. Also I have a scan tool fot each system but can't use either with this stupid connector that GM did this with. Please Help me if you can . Thanks Butch
You can only jump the pins on a 93 model to flash the codes. 94+ models can not be diagnosed this way. You'd need to have it scanned with a scan tool/software. :)
You can't "jump" the pins of a 95, I think the last car you could do that with was a 93. Your best bet would probably be to get a cable and some free software like freescan.
EDIT: He beat me in. |
To add to the complexity, you probably won't be able to have it scanned from Autozone, because they don't carry the 16-pin OBDI connector required to scan it. A dealer would be your best bet.
obd 1 scan tool
can i in some way jump the pins between the connector and my obd1 scan tool I would like to diagnose this today
Re: obd 1 scan tool
Originally posted by streetrat129 can i in some way jump the pins between the connector and my obd1 scan tool I would like to diagnose this today |
Thank You Shoebox that was exactly whay I needed it showed the problem code 29, already have a air pump so thanks again. Butch
