95 motor replaced with 96
Old May 22, 2007 | 08:02 AM
onetransam4u2nv's Avatar
I recently purchased a 96 lt1 with 20,000 miles on it for 1200 bucks could not pass it up . but im wondering its a 96 and my car is a 95 any major problems with swap being its od2 and mines obd1 or any other know problems please let me know.
Old May 22, 2007 | 08:17 AM
always faster's Avatar
I did the same thing with a new 96/97 LT4 .You dont need to modify anything.Its a plug an play thing.
Just put the motor in your car and plug it with your original 95 connection.Remember that its exactly the same engin.
The only difference is that in 96 /97 they got a CPS on the timing cover.Just leave it alone.
Old May 22, 2007 | 08:59 AM
Ricardo's Avatar
The knock sensor is also different in both models.
Old May 22, 2007 | 10:03 PM
cool thanks for the info.
Old May 23, 2007 | 01:34 AM
LeftoverChinese's Avatar
My friend has a 97 and the plug on his coil is different than the one on my 95. I don't know if the 96 would be the same as the 97 or the 95, however, it most likely is like the 97. Although, you can simply reuse any sensors, or in this case, the coil, from your old motor and you should be fine.
Old May 23, 2007 | 07:01 AM
All he got to do is taking the 96 motor and install all the original 95 on it.Including coil icm,knock sensor and bla bla bla
Thats it.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
transam_388
Mar 15, 2015 11:53 AM
Jazsun
Dec 29, 2014 12:14 PM
