95 lt1 will not start whats wrong ?
Old Mar 19, 2009 | 03:01 PM
ghost stripes's Avatar
replaced the ignition switch and the solenoid and starter but still will not even try to crank what else could it be?
Old Mar 19, 2009 | 04:36 PM
BUBBA's Avatar
If it won't even crank the starter then it is probably your battery and/or connections.
I.e. juice flows to solonoid which operates the starter motor which engages the flywheel which turns the crank etc.
Check your fuses too.
Step by step.
Old Mar 19, 2009 | 04:40 PM
rfandkf@rochester.rr's Avatar
check the chip # in the key, it may not match the old one.
Old Mar 20, 2009 | 11:05 AM
battery is fine the switch will not make the starter work
Old Mar 20, 2009 | 01:57 PM
1995blackttopta's Avatar
does your security light come on while cranking? could be a VATS chip problem like rfankdf said
Old Mar 20, 2009 | 02:16 PM
BUBBA's Avatar
M6 or A4?
Old Mar 21, 2009 | 05:50 PM
m6..... is fine the i straight wire the starter and it turns over but will not crank i have fire and have fuel ....i think it might be electrical
Old Mar 22, 2009 | 09:35 PM
MINION's Avatar
if it will start during a push start then it is the neutral safety switch. did you have the ignition on when you straight wired it?
Old Mar 24, 2009 | 11:55 AM
yeah i had the ignition on and the starter would spin the engine over but it would not crank but when you try to crank it with the switch it wont even turn the starter once again i have changed the ignition switch which is what i thought it would be ..the starter is good also....any other ideas would be appreciated ...thanks
Old Mar 24, 2009 | 01:20 PM
tanks14's Avatar
idk, but my z28 wont start either, im thinking either vac. leak or fuel injectors are messed up.
but i want to see what you guys think.
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
APS95Z28
Sep 5, 2002 10:21 AM
formula79
Jul 13, 2002 09:06 PM
