95' Cooling Fan Issue
I have a 95' trans am A4 and recently my fans just quit working. I have a manual fan switch also and that wont work either. I have the fans set to come on at 165 degrees also. This is what I have checked:
-Relays
-Fuses
-Grounds
I also recently have my ignition switch took a [edit], but the car runs most the time, dies once in awhile. Would anything on the ignition switch affect the fans? Any ideas?
-Relays
-Fuses
-Grounds
Last edited by Injuneer; Dec 30, 2011 at 06:11 PM. Reason: Please don't override the language filter
Re: 95' Cooling Fan Issue
Did you check the fusible link?
http://shbox.com/1/1995_pcm6.jpg
In the reference, all 95's are "late production".
Fixed it, its kinda stupid on my part. On the side of the ignition switch you have 2 plugs, the blue plug and brown plug. The brown plug was not snapped in. double checked that and snapped it in and the fans worked again. Everything is back to normal. So for future reference, the brown plug controls fans. Thanks for the quick reply..
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
