95 3.4l to 94 5.7l swap
Old May 1, 2013 | 06:01 PM
james86809's Avatar
I have a 95 3.4l Camaro i removed the v6 and installed the 94 lt1 ive done the whole swap and ive got the car running now but it is dumping to much gas at idle and im getting crazy readings from my pcm.....i originally did the swap about a year ago and i screwed up the wiring under the hood could somebody that has done this swap send me the information needed to match up my 95 3.4l forward lamp harness to match up with my 94lt1 engine harness and pcm i may have a 94 3.4l harness because it does not have a c105 connector on the right shock tower so i guess i need to go back through the wiring could somebody help me out i would appreciate it........also everything inside the car is correct all i had to do inside was run a pcm power supply behind the instrument cluster
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
football4life
Oct 4, 2015 07:48 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
