94z won't start
Old Mar 18, 2006 | 06:26 PM
black94zA4's Avatar
94z won't start
Hello everyone, well a couple of weeks ago I was driving my car and I got on it and it cut out a couple of times around 5k RPM's. Then I stopped at a stop sign and it acted like it was out of gas, but I wasn't. So I had the car towed home, te next day I popped the hood and noticed that the intake elbow was really loose on the intake so I tightened it and it started but it was idling at about 500RPM's I took it on a spin and it ran great as long as I didn't come to a stop sign. So I decided to change the fuel filter, that didn't help any so I changed the plugs. After this I started it and it barely ran at all and I know the plug wires are on good and that the plugs are gapped correctly. So I decided to put on the Opti-spark after taking all the parts off and installing the opti I noticed that the plug that blocks the air silencer on the intake elbow had came off. So I plugged it back up and started it. Both times I got it started before the battery died it only ran for about 5 seconds before it died. Does anyone have any suggestions as what could be causing my problems any help would be great.
Old Mar 18, 2006 | 06:54 PM
Javier97Z28's Avatar
Moderator
Re: 94z won't start
Check fuel pressure.
Old Mar 19, 2006 | 01:10 AM
black94zA4's Avatar
Re: 94z won't start
I'll have to get a fuel pressure guage. It just seems weird that before I changed the plugs it ran great except when I would come to a stop, then I changed the plugs and started it and it ran horrible.
eazyZ
Mar 1, 2015 07:12 AM
Scottyboy
Feb 11, 2015 10:28 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
