94 Z28 mystery problem! HELP!!
Old May 15, 2014 | 10:00 PM
  #61
RMACE's Avatar
Re: 94 Z28 mystery problem! HELP!!
Fred, I got the new MSD opti in and started it and it fired right to life and sounded awesome! It jumped to 1500 rpm and sat steady for the 30 seconds it ran, except for one good rev to about 3k, then I shut it down. Is that normal or is something off? I didn't have MAF or temp hooked up ( no wtr pump yet).
Old May 16, 2014 | 07:48 AM
  #62
The high RPM is the result of the coolant temp sensor not being installed. Just plug the sensor back into the harness, and that will avoid a trouble code. The PCM elevates the RPM on cold start, but max is about 1,200 RPM, and that's down around 0*F. But a non-connected CTS will tell the PCM the coolant temp is -40*F.
Old May 16, 2014 | 02:40 PM
  #63
RMACE's Avatar
Awesome I'm on track then! Thank you! I'm starting to understand this more!
Noenav
Mar 1, 2019 07:38 AM
HCz28
Jan 11, 2015 11:21 AM
ChrisFrez
Nov 23, 2014 10:33 AM
slothgrant
Aug 22, 2002 03:01 PM
Absolute Z28
Jul 19, 2002 02:21 PM
