94 z28 fuel pump r/r-no start
Old Nov 6, 2010 | 03:38 PM
NUR2S's Avatar
94 z28 new fuel pump installed-car won't start - checked all fuses -any ideas?
Old Nov 6, 2010 | 03:47 PM
Re: 94 z28 fuel pump r/r-no start
Does the pump run for 2 seconds when you first turn the key to "on"?
Have you checked the fuel pressure?
Old Nov 6, 2010 | 04:43 PM
NUR2S's Avatar
Pump does not turn on at all-no fuel pressure
Old Nov 6, 2010 | 08:39 PM
Have you tried running the pump via the fuel pump prime connector near the PCM? That bypasses the relay and the PCM interface.
Sounds like you didn't wire the pump up correctly or forgot to plug the harness in.
Old Nov 11, 2010 | 11:14 AM
NUR2S's Avatar
Connection to pump pulled away when springloaded unit reinstalled into tank-reconnected and installed unit with fuel lines disconnected-thanx for the advice injuneer
Gtpguy
Jan 26, 2015 04:50 PM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
blac94Z
Nov 24, 2014 07:12 PM
