Oil pump removal
Old Nov 11, 2010 | 01:04 AM
spike30th's Avatar
Oil pump removal
I need to swap out oil pumps in my 97 Camaro Ss and just wondering if this is possible with the motor still in the car?and if it is what do I need to do?
Old Nov 11, 2010 | 06:17 AM
RamAir95TA's Avatar
Re: Oil pump removal
It's possible with the motor in the car, sure. An engine support bar would make removing the oil pan MUCH easier, IMO, instead of having to finagle lifting it at the right angle to get the pan out.
Of course you'll need to take off the intake manifold too.
Old Nov 11, 2010 | 06:39 AM
bw_hunter's Avatar
Why would you have to take the intake manifold off?
Old Nov 11, 2010 | 12:29 PM
RamAir95TA's Avatar
I would, just to make sure the oil pump driveshaft lined up with the oil pump stub drive. I'm sure you could finagle it up in there, but just to be sure I (personally) would pull the intake manifold just for safe keeping.
Old Nov 11, 2010 | 12:34 PM
bw_hunter's Avatar
Ah, Ok...I see what you mean. However, It's just as easy to pull the pump apart and turn the gears to have it line up. Far easier than removing the intake and just as effective. Besides you should pull the pump apart to load it up with petroleum jelly....
Old Nov 11, 2010 | 12:55 PM
wrd1972's Avatar
No need to pull the intake. The oil pump will not "set" if the drive shaft is not indexed right. If you need further assurance, do what bw said and pull the bottom off and turn the gear.
I have done this a couple of time and obviously getting the pan off is the worst part. Drop all the pan bolts, pull the two big motor mount bolts and lift the motor up as high as it will go by placing the jack under the bell housing. You will have just enough room to wiggle tha pan out through the rear assuming you hold your mouth right.
Make sure the pump is packed full of grease and the pickup is welded on.
Old Nov 11, 2010 | 05:09 PM
spike30th's Avatar
Ok cool thanks for your input guys. I'm pulling the intake any way to check the oil pump drive gear I had to replace the gear once already due to the hv oil pump.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
