94 Z runs rough under light acceleration
Old Oct 26, 2005 | 03:21 PM
shawn 84&92's Avatar
My 94 Z auto with 117 k miles, runs rough under light acceleration. It is worse with a load on it like going up hill. when the revs get above 3k it runs more like it should. At idle, it revs fine and sounds good. Any suggestions?
Thanks,
shawn
Old Oct 26, 2005 | 06:48 PM
bolek's Avatar
Re: 94 Z runs rough under light acceleration
Spark plugs?
Old Oct 27, 2005 | 03:03 AM
DetroitGuy83's Avatar
Could be:
* Spark plug(s)/wire(s), if you do change, don't buy CHEAP autozone wires, use MSD or equivalent! And go with the AC DELCO plugs!
* PCV valve (my car recently stalled and hesitated like crazy because of this little part, it got all gunked up)
* Fuel filter-dirty/clogged
* Restriction in Air Intake (dirty filter)--Maybe even clean your intake manifold with some Carb cleaner.
Old Oct 27, 2005 | 03:09 AM
Depending on when you last had a tune up, you may just need an old fashigoned tune-up. You may suggest changing the Cap & Rotor, and ignition coils.
Cap & Rotor is a bit pricey and it takes a bit of maintenance to change, you have to remove the water pump! I went with the OEM Cap & Rotor, costed $300.00+ I think MSD may have one a lot cheaper, and it's probably better in performance.
bfmv13trivium
Jan 14, 2015 09:57 AM
1775.Z28
Jan 11, 2015 10:51 AM
Scottylt1
Jan 8, 2015 02:48 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Scottylt1
Dec 4, 2014 12:31 PM
