94 wont connect to scanner
Old Apr 26, 2011 | 07:03 AM
Myxtreme1's Avatar
My 94 has not been wanting to crank so I thought I would hook up the scanner. It would not connect period. I entered the cars info and it tried but kept saying connection failed. Coould the computer be bad?
Old Apr 26, 2011 | 07:07 AM
Re: 94 wont connect to scanner
Computer failures are rare. What scanner? Do you have the correct cable? Can you try another scanner?
Old Apr 26, 2011 | 07:50 AM
Myxtreme1's Avatar
I will get the name of the scanner. It is a loaner from Oriellys. It does obd1 and 2. Connector is the correct one. I bought a running parts car the other day so I could check it on that. The car actually started finally but seems to flood itself out.
Old Apr 26, 2011 | 09:16 AM
Myxtreme1's Avatar
Scanner is an Innova CanOBD 2&1 reader.
Old Apr 26, 2011 | 09:29 AM
my1994z28's Avatar
I have a mac scanner and I have to use the cig lighter to power the scanner up on my 94 z.
Old Apr 26, 2011 | 11:55 AM
Unless the scanner is internal battery powered, it may require power from the vehicle's ALDL connector. There is no 12V pin in the 94 OBD-I connector. See note above about powering it from the cig lighter.
Nayr
Mar 3, 2023 08:34 PM
Jeff1904
Jun 5, 2016 05:00 PM
drt
Sep 27, 2015 04:39 PM
plattted
9
Sep 20, 2015 11:23 AM
jackpawt883
Sep 10, 2015 08:53 PM
