94' Trans Am warms up and dies
Old Oct 21, 2012 | 09:53 PM
Meen95z's Avatar
Question 94' Trans Am warms up and dies
94' Trans Am the car starts runs great till 175-180 degrees and just shuts off. Let it cool for awhile starts back up. Check fuel pressure, thats great, have no spark. Swapped coil, icm assembly off a running car, started then about 180 degrees it died. No DTC's.
Old Oct 21, 2012 | 10:54 PM
mrmint69's Avatar
Re: 94' Trans Am warms up and dies
Can you tell if its does it right when it switches to closed loop? You can disconnect the 02 sensors and see if it still happens. Have you checked fuel pressure as it dies? Have you scanned it for codes or just saying there is no check engine light on? Probably something electrical is breaking down after it gets up to temp. Guessing that heat soak may be causing optical cam position sensor in the Opti to fail after getting hot. Here are a couple threads to read. A search will results in 100's of good ones to read.
https://www.camaroz28.com/forums/lt1...-while-782492/
https://www.camaroz28.com/forums/lt1...egrees-772108/
Old Nov 19, 2012 | 03:35 PM
will.b.brown's Avatar
I just went through a similar issue with my 94. When it would reach about operating temp it would start running real bad like it was missing. It seemed alot like ignition issues to me but after alot of hair pulling it turned out to simply need new o2 sensors. ran like new after that
Biggiebound
Apr 20, 2015 07:16 AM
IgorT.455/406
Mar 12, 2015 03:39 AM
Jan 23, 2015 01:13 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
