94 LT1 spark question
Old Apr 21, 2010 | 11:34 AM
RJBAILEY84's Avatar
So i took my car to be tuned yesterday. For some reason the car is breaking down from the 3400- 4500 RPM range. What could cause this. a list follows of things i have replaced.
opti - http://www.jegs.com/i/JEGS/555/40010/10002/-1
coil - http://www.jegs.com/i/MSD+Ignition/121/8226/10002/-1
wires - came with the opti
Plugs - NGK TR55
ICM
everything is fine in park it idles fine. This takes place when you accelerate
Old Apr 21, 2010 | 05:45 PM
Was it having the problem BEFORE you replaced all those parts? Did you buy all those parts to solve the problem. Or was it running "OK" before you replaced the parts, and only exhibits the misfires at 3,500rpm AFTER you installed all the parts?
If it only happened after the install, I'd suppect the Opti. Have you scanned it for codes?
Old Apr 21, 2010 | 06:15 PM
RJBAILEY84's Avatar
just scanned it and it has high resolution code.. So it looks like a new opti....
Old Apr 21, 2010 | 06:19 PM
dangalla's Avatar
while down there with the opti it would be a good idea to take a look at the opti harness
freds question was pretty important though, did this problem arise before or after you replaced the parts?
either way it looks like you may have gotten a bad opti, but fred is the resident expert on this subject, so answer the questions he asks you and you will be on the right track
Old Apr 21, 2010 | 06:44 PM
RJBAILEY84's Avatar
Thanks i just ordered one offline about tweenty mins ago..lol
Old Apr 21, 2010 | 06:47 PM
dangalla's Avatar
you still did not answer the question, but it does not seem like you really wanted any help anyway
Old Apr 21, 2010 | 10:42 PM
I guess we'll never know. Who cares? I really wonder why we do this. Time to move on to something else.
Old Apr 22, 2010 | 09:15 AM
RJBAILEY84's Avatar
Sorry guys read threw it to fast and was trying to do the work to the car at the same time. The problem came after i change these parts. I was just doing a tune up and getting it ready for tune and dyno. The car ran fine, I had a MSD 6AL box on the car and it seem to applify the problem. I disconnected the msd and wired the factory ingition back on and it did better. But its still breaking down at 3400 or so. With everything being new, My assumption is the opti went bad and with msd throwing a hotter spark it just mad it that much worse. The MSD box was sent back to msd in TX and checked out the returned back to me. So it should befine I think.. Thanks for the help guys. I decide to do a cam swap again so im tearing it down for the cam new head gaskets and 1.6 rr. Along with this i will replace the opti once again...
Noenav
Mar 1, 2019 07:38 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
cmdeshon
Dec 27, 2014 10:06 AM
Noenav
Dec 6, 2014 07:35 PM
nophix
Nov 30, 2014 10:26 PM
