94 LT1 in S10, no spark/injector pulse
Old Dec 27, 2018 | 05:35 PM
mynameislance's Avatar
Long story short, I put a 94 LT1 in my s10. The engine ran before I put it in, now it won't run. I have no spark or injector pulse. Using TunerPro I see no codes and no RPM when cranking. I've done all the tests people talk about for the opti and I don't have the 4V AC going to the ICM. I bought a new MSD opti and put that on, no change. I'm at a loss of what to do. Are people still getting new opti's that don't work? Is there anything I can do to test it not installed? I don't have an oscilloscope.
Is there something simple I might be overlooking here like a ground or something? The harness is a custom harness I had built for the engine/truck by an aftermarket harness company. I've checked all the power and ground wires going to the ECM and they all check out fine. I have have a ground from the harness to cylinder head and frame, battery negative connected to block and body.
Any help would be greatly appreciated
Old Dec 27, 2018 | 08:34 PM
Re: 94 LT1 in S10, no spark/injector pulse
Post #6 in this thread offers a way to test the Opti without installing it, no ‘scope, just a volt meter:
https://www.camaroz28.com/forums/lt1...9/#post7001193
Yes, brand new Optis right out of the box are still failing. The MSDs are just as bad, with failed units being rebuilt by MSD, and not working when returned. Then there’s the problem with erratic timing signals causing huge idle surge, but that's only once you get it running, and mainly on MSD units manufactured over the past 2 years or so.
Appears you confirmed the Opti harness connections:
4th Gen LT1 F-body Tech Articles
Does the MSD have a permanently attached harness? With the older factory harness connector into the Opti I've seen at least one case of trying to push a (short) 93/94 connector into a 95-97 Opti that require a “long” connector, doesn’t make a good connection. Wouldn’t seem to apply here though.
Old Dec 27, 2018 | 08:43 PM
Thanks for the link, I’ll try that out tomorrow. Does it have to be a high quality multimeter or Will a cheap one work?
Yes this has the permanent harness on the Opti.
Old Dec 28, 2018 | 08:02 AM
Simple volt meter, in this case measuring DC volts.
Old Dec 28, 2018 | 01:57 PM
Well I didn’t see the voltage but I did hear my injectors clicking and see spark coming off the coil to Opti wire (was unplugged), so I guess I do have spark and injector pulse. I feel like an idiot now.Not sure why I couldn’t see the 4VAC. Crappy multimeter I suppose. Guess I’ll move on to checking the fuel system. I can hear fuel flowing but maybe too low of pressure? It’s a new after market pump for LS1 swaps so should be enough but I’ll find a gauge and check it.
“high pressure 255lph MSD in-line pump capable of 43 gph @ 40 psi or 39 gph @ 80 psi”
Old Dec 28, 2018 | 04:46 PM
Pump specs sound odd. The stock in-tank pump flows more than that. 43 GAL/HR is only 163 LPH.
The LS1 needs a “higher pressure” pump because the fuel system operates at 4 bar (58 PSI). The stock pressure for the LT1 is 3 bar (43.5 PSI). You can run the fuel system at any pressure you want, but when you raise pressure, you have to calculate the increased fuel flow through the injectors, and load that info into the PCM program, so it can calculate the correct injector pulse widths.
Old Dec 28, 2018 | 05:24 PM
My engine still has the stock regulator on the fuel rail though. It doesn’t even stumble or try to start, I would think even if the pulse widths were off it would still fire somewhat.
Old Dec 28, 2018 | 05:27 PM
That quote I sent before was what it said about the pump in a kit I ordered, when I actually go to the pump the numbers make more sense
https://www.speedwaymotors.com/MSD-2...lQuery=5472225
Old Dec 28, 2018 | 08:53 PM
Same numbers you quoted. Just puzzling how a pump that flows 163 LPH free flow can be considered a 255 LPH pump. For example, the Walbro 255 LPH high pressure in-tank pump that is the standard upgrade for LT1 users flows 59 GPM at 40 PSI, and 42 GPM at 80 PSI (12 volts). Free flow (0 pressure) is 76 PSI.
I guess the flat flow curve is typical of the roller vane pump type.
Old Dec 31, 2018 | 08:39 AM
Fuel pressure was around 43 psi, no injector pulse though. I tried putting a little gas in the air intake and it did try to fire. I’m back to thinking it’s VATS. The place who built my harness told me it would still start but then die if it was VATS but after reading about it more and looking at the schematics, where the “fuel enable signal” goes into the pcm there is no wire. I have a ALDL usb cable on order to turn vats off.
Old Dec 31, 2018 | 09:41 AM
The fuel enable signal is a 30-Hz (1993 only) square wave, that comes from the theft deterrent module. There is simulator module you can buy (or make) to provide that signal.
Old Dec 31, 2018 | 10:14 AM
Hmmm...so that signal was only on 93 engines? Does it matter if it’s from a Camaro or Firebird? My engine is from a 94 Firebird Formula.
Old Dec 31, 2018 | 01:55 PM
Sorry, I had helped someone with a 93 on another site, and forgot to shift gears to my brain's 94 database. Unfortunate sign of old age
The same system exists in all 4th Gen F-Bodies Firebird/Camaro. The frequency is 50 Hz for 94 and newer. The frequency depends on the year of the ECM(93)/PCM(94 and up), not the engine. The module available at Amazon can produce either frequency with a minor wiring change.
Amazon Amazon
Old Dec 31, 2018 | 05:03 PM
Oh gotcha...I’ll just turn it off in the PCM. Hopefully that solves my problems.
Thanks for all the help!
Phillip May
Aug 16, 2013 10:36 PM
Phoenix_fire
Mar 20, 2012 10:28 PM
BlkZ28Kreepn
Mar 14, 2008 10:11 AM
LTgun_94
Mar 1, 2007 08:55 PM
Kreinmc
Advanced Tech
11
Jan 27, 2003 10:05 AM
