94 camaro Electrical demons - Ignition
Old Mar 20, 2012 | 05:59 PM
Phoenix_fire's Avatar
I'm having issues with my 94Z shutting off intermittently. Ive read the codes and its showing a loss of low res pulse signal. Having already replaced the Opti, the Opti harness, and the PCM, i'm left at a loss as to why this is happening. Anyone Help?
Old Mar 20, 2012 | 06:13 PM
mrmint69's Avatar
Re: 94 camaro Electrical demons - Ignition
https://www.camaroz28.com/forums/lt1...d-opti-755407/
https://www.camaroz28.com/forums/lt1...c-16-a-652038/
These should help out.
Old Mar 20, 2012 | 07:13 PM
I appreciate the links and have investigated those options. Since i've already replaced the opti with an accel unit, replaced and re-programmed the PCM, and replaced the opti harness, the last link is in the Master engine harness. Any Ideas?
Old Mar 20, 2012 | 10:28 PM
With what you did, I would suspect the Accel unit, first. Many people have had less than stellar results with it. The AC-Delco/Delphi/GM opti has about the best track record out there.
liamcg97
Nov 25, 2019 05:55 PM
Ari G
Dec 11, 2014 03:21 PM
lbrowne
Nov 13, 2011 04:25 PM
Jul 4, 2005 05:00 PM
slothgrant
Aug 22, 2002 03:01 PM
