94 LT1 not starting after opti replacement
Old Jul 13, 2008 | 11:09 AM
Renfro78's Avatar
so i spent the greater part of saturday replacing the opti on my formula. everything was goin smooth until it was time to start it up again. all it wants to do is sit there and turn over. we arent getting any spark from the coil and i went ahead and replaced the coil and the ignition coil module too and still no spark. if anyone can give me some type of information on this i would really really appreciate it.
Old Jul 13, 2008 | 12:07 PM
Did you index the opti correctly and check the electrical connector for any corrosion or contact issues?
Old Jul 13, 2008 | 02:58 PM
Renfro78's Avatar
i do not know what indexing the opti means lol im new to the opti and all the connectors are clean on everything
Old Jul 13, 2008 | 03:47 PM
It means there is a certain way it is supposed to be installed. If you did not know that, then it's probably not. The stub drive shaft of the opti is indexed into the back of the opti and also the cam gear.
Old Jul 13, 2008 | 04:34 PM
Renfro78's Avatar
when we put the opti back we lined the notches on the little shaft that connects the opti and the motor together but other than that we didnt notice anyother way to install it. thanks for being helpful btw i really appreciate it
Old Jul 14, 2008 | 06:17 AM
Have you checked it for codes?
Old Jul 15, 2008 | 06:17 PM
Renfro78's Avatar
yea we checked for codes today with a gm tech 2 and nothing came up, the opti isnt brand new i bought it used from another member on here and i think he might have screwed me over.
Injuneer
Dec 15, 2014 09:36 AM
pologreen97z
Dec 2, 2014 10:42 AM
USAirman93
Nov 24, 2014 03:37 PM
1LEThumper
Jul 14, 2003 12:45 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
