94 and 97 tb bypass
Re: 94 and 97 tb bypass
No... 93/94 is different than 95-97.
For the 94, you pull the two lines of the bottom plate of the throttle body, and connect them together using a 3/8" barbed hose connection and two clamps. For the 97, you pull the short hose off the passenger side connection on the TB plate, and discard it. Pull the hose off the drivers side connection on the TB plate, and connect that hose where the discarded hose used to connect.
Caps are 3/8" for the TB connections.
colts0455
Sep 2, 2015 12:41 PM
