94 and 97 tb bypass
Old May 14, 2005 | 03:41 PM
camarolover20's Avatar
94 and 97 tb bypass
Are the 94 and 97 Tb bypass the same?Can i run the line from the rad. to the steel line on the head?Also can anyone tell me what size the vac caps are for the TB?
Old May 14, 2005 | 03:51 PM
Re: 94 and 97 tb bypass
No... 93/94 is different than 95-97.
For the 94, you pull the two lines of the bottom plate of the throttle body, and connect them together using a 3/8" barbed hose connection and two clamps. For the 97, you pull the short hose off the passenger side connection on the TB plate, and discard it. Pull the hose off the drivers side connection on the TB plate, and connect that hose where the discarded hose used to connect.
Caps are 3/8" for the TB connections.
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
colts0455
Sep 2, 2015 12:41 PM
