94-95 pcm in a 93?
Old Sep 14, 2006 | 09:28 PM
93 camaro z28's Avatar
94-95 pcm in a 93?
hey guys, i have a 93 camaro. im getting tired of having new chips burned every time i do something small. not to mention the chip is burned for my mods but every car runs alittle different and need different tuning. i want to be able to tune my car with a labtop. is there anything special i would have to do to put a 94-95 pcm in my car. i know i will have to get the wiring harness and maf. what esle would i need? and does anyone know where i can find this info. thanks for your help
Old Sep 14, 2006 | 10:11 PM
sbs's Avatar
sbs
Re: 94-95 pcm in a 93?
You wouldn't have to get a MAF, you could continue to use SD mode.
With the 93 you don't have to worry about having a dead car while you send the PCM out for repair after a bad flash...
Old Sep 14, 2006 | 10:25 PM
ya, i understand what your saying but i still want to be able to tune it with a labtop. o ya, i am used to having a "dead" car. it breaks all the time, lol. should i just be able to get the pcm and wiring harness from another lt1 and it should run just fine? after a tune of course for my mods
Old Sep 17, 2006 | 09:01 AM
Guest47904's Avatar
Guest
You can just as easily program the PROM as you could the later model PCMs. I personally like the idea of a PROM since you can always keep a "stock" PROM to plug in in the event of a bad program rather than have to down load another program.
Also, your 93 is batch fired injectors. It's not clear if the wiring for each injector is set up so the later PCMs will function correctly for them to be sequential. I don't have the wiring diagrams for 93's to answer that but I'm sure someone here will chime in.
Old Sep 17, 2006 | 09:32 AM
sbs's Avatar
sbs
He stated in the first post that he realizes he has to upgrade the harness.
Old Sep 17, 2006 | 01:16 PM
ya i realize i need a wire harness. also i want to be able to tune it on a labtop, because there is no where around this area that can dyno tune a 93 lt1 because they don't have the tools to do it. but there is a few that can do it for 94+. thanks
Old Sep 17, 2006 | 01:49 PM
hey, if i read this right, this plugs into the computer where the eprom usually plugs in, and you can tune it!! http://www.moates.net/ostrich-real-t...ator-p-57.html am i right? is there finally something you can tune a 93 on the fly with? thanks
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
