94,95,&96 LT1 shortblock?
Old Jun 17, 2007 | 05:24 PM
  #16
1racerdude's Avatar
Originally Posted by SNAKE_EATER
Now I have also heard conflicting stories that my Opti(non vented) will not fit on the 95 or 96 timing cover is that true?
True
Go on eBay and get a cover for a '94 or an opti for a '95/'95
Old Jun 17, 2007 | 05:27 PM
  #17
NovaTodd's Avatar
You need to run the 94 timing chain, cam, front cover, and distributor as they are different than the later ones
These parts have to match each other:
The timing set has splines to run the earlier opti spark
The timing cover seals to the opti drive shaft
The cam pin is shorter on the earlier cam as it does not drive the opti.
Old Jun 17, 2007 | 11:34 PM
  #18
Originally Posted by hotrod18_69
My mistake.. Some 95 years came with a vented opti.. Hence a vented timing chain cover..
Another mistake. ALL 95 LT1's have the vented Opti, and the unique 1995-only timing cover.
Aren't the rods out of 96-97 rods consider "PM" rods? Powder Metal...
Yes, starting in mid-94, all LT1's got the PM (powdered metal) rods. I was simply pointing out that this change was not made in 1996, which is what was stated in one of your posts above.
Old Jun 18, 2007 | 09:45 AM
  #19
SNAKE_EATER's Avatar
Thank you all very much this thread has cleared up ALOT of confusion.
Old Jun 18, 2007 | 03:00 PM
  #20
The hot cam came out of the 95 will that be a problem?
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
Chevyguy358
Jan 28, 2015 08:04 PM
Queens94z28
Nov 20, 2014 06:03 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
