93 z28 tach dont work, when accelerating it drops to zero. Have wires unpluged under
Old Sep 24, 2019 | 01:47 PM
Daron Neal's Avatar
What does this go to?
Old Sep 24, 2019 | 01:49 PM
Daron Neal's Avatar
Re: 93 z28 tach dont work, when accelerating it drops to zero. Have wires unpluged un
One wire coming in is purple and white and the other is white with black.
Old Sep 24, 2019 | 02:02 PM
Does the tach work when not accelerating - at idle?
1993 LT1 tach is different than all other years of the LT1. It is driven off the coil, where all other years get their signal from the PCM.
Here's the 93 wiring diagram (courtesy of Shoebox), showing the tach filter (also unique to 93), connected to the coil, and having a white wire that goes to the instrument panel.
http://shbox.com/1/93_ign_system_schematic.jpg
The purple/white and white/black wires are most likely the VATS (PASS-Key) wires from the ignition lock cylinder to the VATS Module. Someone may have done the resistor bypass.
Again, from Shoebox
http://shbox.com/1/vats_bypass.jpg
Old Sep 24, 2019 | 05:04 PM
Daron Neal's Avatar
It sits on the one at idle, when u accelerate or rev it acts as if it may go up then drops to zero.
Old Sep 26, 2019 | 05:08 AM
Daron Neal's Avatar
What would be my best chance at fixing the tachometer? Anyone have any suggestions?
Old Sep 26, 2019 | 08:54 AM
Unless someone owns a 93, with its unique tach feed, unlikely we can offer good suggestions. I've been here 20+ years and don’t recall a similar problem with a 93. I'll take a look at the troubleshooting section of the 1993 factory service manual to see if the problem is addressed. Or you can get the free download of the manual (courtesy of GaryDoug) and take a look:
https://www.mediafire.com/?40mfgeoe4ctti
Logically, the problem could be a defective tach filter, a problem with the tach/instrumental cluster, or a loose wire that flexes when the engine moves under a high torque loading.
Old Sep 28, 2019 | 02:05 AM
Daron Neal's Avatar
Thank u ill attempt a download, it doesnt hurt to ask and i appreciate all the input and help i can get..
Old Oct 11, 2019 | 12:39 PM
The SRZ's Avatar
Daron, you ever get it sorted out? I have an issue with mine where it flutters at idle and doesn't rev at all. I'm coil over plug though but it use to work and now it's just flutters.
Old Oct 15, 2019 | 07:10 PM
Daron Neal's Avatar
Ive been trying to trace down wires, but im bout to sum it up as a bad tach filter
flusz28
Sep 18, 2004 07:04 AM
93Z4ME
Jun 27, 2004 08:24 PM
Gripenfelter
May 20, 2004 08:20 AM
OneBadLT123
Sep 26, 2003 03:23 PM
ltwonz
Mar 18, 2003 11:28 AM
