93 z28 bangs when starting
I went to go buy a 93 z28 and when the guy started the car there was a loud pop. The guy said it’s the starter and that it has done every time he starts it since he owned it. Before buying the car I wanted to check to see if anyone had an idea of what that is.
Re: 93 z28 bangs when starting
Was the engine cold or hot when the owner started it? The starter wouldn’t cause a backfire (popping in the intake manifold) or popping in the exhaust. It is more likely a problem with unburned fuel in the system, a valve hanging open, or an ignition timing error.
Is the engine basically stock, or has it been modified? If modified, what was done to it?
91 Camaro RS
Oct 2, 2005 04:00 PM
