93 z28 bangs when starting
Old Feb 23, 2019 | 11:18 PM
Logan Jones's Avatar
I went to go buy a 93 z28 and when the guy started the car there was a loud pop. The guy said it’s the starter and that it has done every time he starts it since he owned it. Before buying the car I wanted to check to see if anyone had an idea of what that is.
Old Feb 24, 2019 | 07:07 AM
JakeRobb's Avatar
Super Moderator
Re: 93 z28 bangs when starting
Can you describe the sound more? Are we talking backfire? Or does it sound like parts banging together?
Old Feb 24, 2019 | 08:20 AM
I thought it sounded like a backfire. It only happened when we started the car and didn’t happen again
Old Feb 24, 2019 | 09:57 AM
Was the engine cold or hot when the owner started it? The starter wouldn’t cause a backfire (popping in the intake manifold) or popping in the exhaust. It is more likely a problem with unburned fuel in the system, a valve hanging open, or an ignition timing error.
Is the engine basically stock, or has it been modified? If modified, what was done to it?
Old Feb 24, 2019 | 04:13 PM
he said it has a 93 gas tune and he said the gears were changed on the car. It could have been a different noise than a backfire and the popping noise was from the engine bay. The guys had driven the car about an hour before we got there so it probably was cold. I think the car needs a new opti based on how it drove. Idk if that could cause a popping noise on start up though. It also needs a new tranny mount but I don’t think that would cause a pop on start up.
Old Feb 25, 2019 | 09:35 AM
Could be the rotor in the Opti is cracked or coming loose, or carbon tracking in the Opti = timing error.
maliveline
Sep 4, 2011 08:38 AM
91 Camaro RS
Oct 2, 2005 04:00 PM
Zpower
Apr 2, 2004 09:56 PM
