93 (speed density) to 97 harness swap
Old Dec 31, 2006 | 08:19 AM
chevroletfreak's Avatar
What has to be done to run a 97 harness in my 93. I will be swapping over to an engine/intake setup to run with the harness and PCM.
What about guages, sensors, 6 speed trans connections.....
Thanks for any info!
Old Dec 31, 2006 | 12:19 PM
red94chicken's Avatar
if you are just swapping the engine then you wouldn't really need to swap the harness... you old harness will hook up to your new engine.. just leave out the maf and the crank angle sensor won't have to have to be plugged in either. its not so easy making a different year harness work.. i went through all of this a month ago cause my harness was no good thanks to the previous owner.
DirtyDaveW
Dec 1, 2016 05:37 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
jayvar
Feb 2, 2015 10:00 PM
Jul 4, 2005 05:00 PM
