93 LT1 Priming oil pump and motor
Old Oct 15, 2010 | 09:23 PM
tree95zlancca's Avatar
I am getting ready to install new motor in my 93 z28. Can anybody tell me how to prime the oil pump and motor before instaling and starting?
Old Oct 15, 2010 | 09:48 PM
You use an SBC priming tool with a drill, but the intake manifold has to be off to do this.
Old Oct 16, 2010 | 06:11 AM
tdeal28's Avatar
Just pull all of the spark plugs out and crank the engine over until you build oil pressure.
My 97 Camaro sat in my garage apart for a year and a half and I didn't have any issues doing it this way.
Old Oct 16, 2010 | 10:06 AM
ChevalierSS's Avatar
I removed the fuel injector fuse and cranked the motor w/ the starter
Old Oct 16, 2010 | 10:13 AM
Rather than pulling wires off the plugs and pulling injector fuses, simple unplug the gray Opti connector on the bracket on the passenger side of the intake manifold.
Old Oct 16, 2010 | 10:30 AM
ACE1252's Avatar
Pulling the PCM fuse will do the job as well.
Old Oct 16, 2010 | 12:22 PM
Thanks Rob for giving me the correct way to do this. What is the SBC tool and where do you get one?
Old Oct 16, 2010 | 03:19 PM
Small Block Chevy priming tool. Any speed shop or Summit, Jegs or some auto parts stores, etc. should have one. Make sure it has a collar (blue piece on right in pic below) that fits in the hole by the cam.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
guionM
69
Nov 30, 2006 02:01 PM
