93 hot cam dowel pin
Old Mar 3, 2003 | 07:47 PM
Thor39's Avatar
How am i supose to pound the pin down with out damaging the pin or cam Just wondering how evey one else done it?
Old Mar 4, 2003 | 06:54 AM
IDOXLR8's Avatar
I used a set of vicegrips and hammered the pin out. I think you are going to have to get a longer dowel pin anyway. You can go to your local machine shop and pick up a longer pin.
Old Mar 4, 2003 | 07:04 AM
Smoke T/A's Avatar
If you bought the cam from gm just place it on a piece of wood and tap it in till it is the same length as the dowel on your stock cam. HTH
Joe
Old Mar 4, 2003 | 09:26 AM
Smokn '94 Z's Avatar
Joe
Exactly!!
Old Mar 4, 2003 | 10:25 AM
94 CAMRO Z28's Avatar
I was not able to tap my pin in, it went a little bit and then wouldn't budge. I simply used a dremel to grind it down the right length.
Aaron
jj_burchiel
Mar 5, 2015 07:05 AM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Smokn '94 Z
Aug 4, 2002 06:11 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
