93 harmonic balancer removal question
Old Mar 31, 2013 | 12:21 PM
rocknroler69's Avatar
Hey guys just a quick question. I'm doing the opti in my 93z28. I went to pull the balancer off and none of the bolts in the puller kit seem to fit, what size do I need?
Old Mar 31, 2013 | 03:44 PM
Re: 93 harmonic balancer removal question
Only the pulley needs to come off to do the opti. If you cannot gently tap or coax it off, you need to use a jaw puller to remove it.
Old Apr 3, 2013 | 06:54 PM
oh really? I have the gm manual and that says to use this kind of puller. If that works though I am more than willing to try it
Old Apr 3, 2013 | 09:00 PM
You do know there are two parts, right? The pulley and the hub. The pulley is bolted to the hub. The hub does not need to come off to remove the opti. All truth.
Old Apr 3, 2013 | 09:20 PM
divineprime's Avatar
Be sure to mark the pulley relationship to crank shaft hub snout. I scribed mine in two places but you could use paint or marker too. Makes it easier to throw back on afterwards.
Old Apr 3, 2013 | 09:27 PM
The pulley can only go on one way, so you can't make it go back on wrong. The spokes of the hub are not symmetrical. The pulley and hub are already marked. The pulley has an arrow and the hub has a cast line on it. Those should be at the same place.
http://shbox.com/1/engine_front_diagram.jpg
Once the pulley bolts are out, the only thing holding the pulley on is the friction/rust fit of it to the hub.
Old Apr 5, 2013 | 04:37 PM
Yes I'm aware there are 2 parts. Like I said, the GM Service manual that I have says to use a puller to get the balancer off. I will try what you suggest next time I get a minute to work on it. Thanks
Old Apr 5, 2013 | 09:37 PM
Actually, it does not say this. The instructions are for removing the balancer and hub. Step 1 says to remove the balancer bolts and balancer assembly. No mention of a tool, until step 3 for removing the hub.
What I have on my site is helpful if the balancer is stuck on the hub.
Old Apr 7, 2013 | 12:12 PM
Wow, my mistake, you're right. I just looked in it again, I had been reading it wrong all along. Thanks
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
1963SS
Feb 6, 2015 10:05 AM
smokin5s
Jul 24, 2003 10:47 PM
1LEThumper
Jul 14, 2003 12:45 PM
