93 to 94 PCM HARNESS Conversion HELP!
Old Apr 1, 2005 | 04:18 PM
  #16
ZPaul2Fresh8's Avatar
Re: 93 to 94 PCM HARNESS Conversion HELP!
Ok, I disabled VATS, no deal....
I was able to log a sec or two... I'm getting DTC #42 EST Grounded
I'm gonna search for definitions... any thoughts?
Thanks.
Old Apr 1, 2005 | 09:20 PM
  #17
Max 93's Avatar
change the ign. module. I was getting that code also when I did the swap, but my car still ran fine. I changed that and havn't got a engine light since.
Old Apr 2, 2005 | 07:36 AM
  #18
Thanks I will try that today. I won't make it to the track, it's raining
Max93, you said your car ran fine, well mine will start an then die after 2 seconds... I hope it IS the ICM....
I've been doing all the testing I can think of, from checking continuity on all the wires to checking the ground wire. Everything checks out ok. The PCM is known to be good.
It runs good for the 2 secs until the PCM throws a DTC42, then it cuts out the fuel.
Old Apr 2, 2005 | 08:31 AM
  #19
Max 93's Avatar
mine would run for a few minutes the the engine light would come on, but would still run fine. I tested every thing also and found nothing wrong. I bought a module for a 94 and all was good.
force10
Aug 10, 2015 08:30 AM
88IROC_Z
Jul 22, 2015 11:38 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
RUNMYTA
Jul 15, 2015 07:50 PM
asilomar244
Jul 12, 2015 05:53 AM
