93/94 LT1 long block into 95 Z28
Old Jun 4, 2006 | 10:22 PM
89Vert's Avatar
I found a long block I want to build up while the stock motor is still in the car
basicly want to know what is involved in swapping the Opti spark
vented vs non-vented
is it a simple bolt on or is it more involved,
Old Jun 4, 2006 | 10:24 PM
MyShibbyZ28's Avatar
Re: 93/94 LT1 long block into 95 Z28
The camshaft/driving mechanism is different. That's about all I know.
Old Jun 4, 2006 | 10:59 PM
The much referred to site..
http://para.noid.org/~muttvette/opti.html
Old Jun 4, 2006 | 11:39 PM
89Vert's Avatar
Old Jun 5, 2006 | 07:23 AM
Is it a 93 long block or a 94? The intake manifold will be a problem (if its included) on a 93. And a 93 or early 94 will need to have the oil pressure sensor relocated.
Old Jun 5, 2006 | 08:09 AM
v7guy's Avatar
the knock sensor from the 95 won't work on the earlier blocks if I remember right.
Old Jun 5, 2006 | 03:15 PM
No. 93-95 use the 4.5Kohm sensor, 96/97 uses the 100Kohm unit.
Old Jun 9, 2006 | 02:50 PM
v7guy's Avatar
thanks for correcting my misinformation.
11racing
Classic Engine Tech
Dec 26, 2014 05:40 PM
Bearmans
Dec 3, 2014 05:28 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
RedLineRev
Jan 23, 2003 03:51 PM
