help with high idle coming to a stop!
Old Jun 8, 2006 | 10:23 PM
RedWS6TA's Avatar
i have searched on this subject but i cant really find an answer. i have access to a tech 2 scanner at gm. and i am pretty sure i have the tp set right(.67) and the iac counts are around 60-70. i have a heads and cam car with a madz28 tune and when coming to a stop i can take the car out of gear or push in the clutch and the rpms go to about 2000 and stay there until i completly stop and then they go down. i just to day sprayed a throttle body cleaner in the throttle body and the iac hole in the throttle body but the problem is still there. thanks for any help
Old Jun 9, 2006 | 01:37 AM
whitehooptie's Avatar
Re: help with high idle coming to a stop!
Sounds like you need to have your counts readjusted for your temps.
Old Jun 9, 2006 | 06:00 AM
RedWS6TA's Avatar
is that something that is in the tune? i am not sure of how to do that. i am going to have the car dyno tuned tommorow. i am just trying to get everything working good before i go. i dont want to get there and them say i need to do this or that before they can tune it. i am having to drive 3 hours to get it done so just tring to cover my own ***.
Old Jun 9, 2006 | 11:15 AM
Mike96z's Avatar
Could be a slipping clutch if you have a M6 or possibly cam surge.
Old Jun 9, 2006 | 01:33 PM
RedWS6TA's Avatar
how would that be a clutch slipping if the car is out of gear and rolling to a stop?
Old Jun 9, 2006 | 01:46 PM
97WS6SCharged's Avatar
Sounds like the throttle follower table is slightly out of whack.
Old Jun 9, 2006 | 03:15 PM
Mike96z's Avatar
If your clutch is going out, instead of fully disengaging when it's suppose to it may stay engaged a little longer or slightly and can cause higher rpm's, mine is doing the same thing as yours and it's my clutch, and when I take off and punch it the clutch slips all the way through my rpm range and when I shift the same thing and it doesn't go anywhere. But under normal driving conditions the clutch seems fine. Sometimes hard to get into first. Just a suggestion, if your clutch is over 100k or so I'd recommend replacing newayz.
edman
Jan 25, 2015 02:41 PM
Jan 23, 2015 01:13 PM
David Dorris
Jan 17, 2015 08:10 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
