87 octane
Old Mar 2, 2003 | 10:08 AM
97ramairtransam's Avatar
87 octane
i am wonderering what 87 octane will do to my car is it ok to run it ?please someone tell me that actully has tried it.its what ive been running for like a month since i got my car running again it i am gettin bad gas millage and a random multi cylinder misfire code.and my car is running like crap could this have anything to do with it
Old Mar 2, 2003 | 10:15 AM
Crazy8's Avatar
I have been running 87 in my car for the past couple of times that I have filled up because the price is so high and I havent noticed anything different in the way the car runs. Seems to me that they are about the same. Thats just my opinion.
Old Mar 2, 2003 | 10:24 AM
Max 93's Avatar
last summer my dad borrowed my car and he put 87 in it. When I got back into my car it had no power. next fill up with premium and all was good. I assume the computer was retarding the timing. There were no misses and it ran fine, just down on power.
Old Mar 2, 2003 | 10:38 AM
Z28ROC's Avatar
A long time ago. A friend of mine put 87 in my Z, without me knowing it. Later that day I heard audible knock and ping. I didn't have a scanmaster at the time, so I don't know how much timing was being pulled. Well I figured it out and topped it off with 92. The knock went away immediately. I'd stay away from it if I were you.
Old Mar 2, 2003 | 08:58 PM
Poorboy94Z's Avatar
The misfiring you speak of could be more than just a low octane gas. It could be a number of things. I would stick with a higher octane gas because high compression engines need higher octane gas. LT1 are high compression engines and would benifit from higher octane gas. As far as your miss. I would put new plugs and wires in it. I just did it to my car last week. Buy my problem ended up being the opti-spark. But try plugs and wires. Putting new O2 sensors in will help your gas milage out too!! Good luck
Old Mar 2, 2003 | 09:18 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
guys, premium is sold for cars like ours don't cheap out and hurt your engine with 87 octane... we have a responsiblity to take care of these engines cause they will never be made again... that mis your talking about is probably dtonation... premium dude premium
Old Mar 2, 2003 | 09:42 PM
PredatorZ28's Avatar
i used to run 87 without a problem and now i just started using 91 again and my car just threw a ses light and the fan is on all the time.. going to get it scanned soon
Old Mar 3, 2003 | 06:12 AM
UkraineTrain350's Avatar
if the car is required to run premium gas, why wouldn't you?? you're damn lucky you have knock sensors or these posts would turn into "i blew a hole through my piston after running 87 octane"
Aug 24, 2015 06:41 AM
dkred94z
Aug 20, 2015 03:09 PM
kahouna23
V6 Tech
Feb 10, 2003 06:08 AM
frankjr8
Feb 8, 2003 11:03 PM
camaro98_speed
Dec 14, 2002 03:50 PM
