7.200 or 7.150 pushrods
Old Feb 8, 2006 | 07:11 AM
  #16
cehan's Avatar
Re: 7.200 or 7.150 pushrods
Let's see, how's that old saying go?...there's never time to do it right, but there's always time to do it twice.
Chris
Old Feb 8, 2006 | 08:17 AM
  #17
jsetzer's Avatar
From a personal experience, milled heads and an 847 "can" need shorter rods. Ask 96ta(nick) he chewed through a set of guide plates and then spun a cam bearing out of the block. (with 7.2 pushrods)
Check it!
We checked mine before putting the motor in the car. With the cc306 I am going to go a tad shorter than stock, but use 7.2's just to get it running until I can order some 7.1s.
Old Feb 8, 2006 | 09:51 AM
  #18
TransAm396's Avatar
yeah i think im going to just go with 7.150's less wont hurt as much as too much..plus im taking .050 off anyways with the smaller headgasket and shaved heads
Old Feb 8, 2006 | 09:57 AM
  #19
Jeff95TA's Avatar
Originally Posted by cehan
Just FYI. When I was doing the geometry checking, I thought about checking the length of the original stock pushrods that came out of the engine (from GM as it was assembled at the factory). I made a fixture to set up the stock pushrod in and used the Comp Cams pushrod checking tool to determine the actual length of the stock pushrod. THE STOCK PUSHROD WAS 7.150" !! I alway heard that they were 7.200". Just goes to show you, you can't believe everything you hear.
Chris
How did you use the checking tool to determine the length? Did you use calipers at any point?
Old Feb 8, 2006 | 10:00 AM
  #20
SStrokerAce's Avatar
Chris
I love this saying!
Proper pushrod length is going to help make the valvetrain work properly AND not wear out the guides. Too short of a pushrod will develop problems of valve control around the seat which usually hurts power badly.
Bret
Old Feb 8, 2006 | 05:54 PM
  #21
TransAm396's Avatar
I just talked to LE..he said I could just go with the 7.2's Which is what im going to do..i cant wait..i got a heated garage to work in now..alls I need is more days off to get this beast going.
Old Feb 8, 2006 | 07:29 PM
  #22
LT1inaMGB's Avatar
If you don't want to take everything apart you can use one of the length checkers from Manley (available from Jegs) and an adjustable pushrod and it will get you very close. The part is only about $15 and is easy to use. There are also clear and detailed instruction on how to use it on the net if you Google "pushrod length checker".
Jim
Old Feb 8, 2006 | 07:55 PM
  #23
BMAN'S SCZ's Avatar
This is what Lloyd emailed me when I ask him the same question.
"I have mocked up stock bottom ends with my heads and my cams (4.960" length valve, milled .010-.020, stock block deck ht and Impala gasket with my cams and the base circle I use and the lift of my cams). I know what THIS set up needs.
Any time you change ANY of this stuff and use diff valve length, valve job depth, changing head castings, milled diff amounts, diff block decking, diff head gasket thickness, cam base circle, cam lift, etc, etc, etc, you really need to mock it up and see what it looks like.
Start by using some "test" valve springs so the real valve springs do not compress plunger in lifter and throw things off. Color in top of valve with black market and rotate engine over by hand a few times. Look at the wear pattern on top of the valve and see how "centered" it is. Adjust pushrod length .050" shorter and re test. Keep adjusting pushrod length in .050 increments until the wear pattern is most centered.
"Most" set ups need a stock 7.200" length and if they vary at all it will be only .050" shorter or longer.
This is the ONLY way to KNOW what pushrod length you need."
Lloyd
Heard you got a good deal on those LE2's Good luck......John
Old Feb 9, 2006 | 07:13 AM
  #24
cehan's Avatar
I C-clamped two short lengths of scrap 3/4" angle iron to my bench, with the stock pushrod between them and squared up. Then using my Comp Cams #7702 Hi Tech pushrod checker, I adjusted it so that it was identical length to the stock pushrod. When it was the same length, I just counted the number of turns it was out from the fully retracted position. Each full turn is 0.050"; 6.8" + (7 x .050") = 7.150"
Chris
13qtr
Oct 28, 2016 08:11 PM
Quickss96
Jan 29, 2016 05:56 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
94Form
Jul 17, 2015 10:56 PM
