6" 5.7" rods 350ci
6" 5.7" rods 350ci
can i run 6 or 5.7" rods with stock crank?? i see theres 2 pistons with difernt pin hights. im geting eagle h-beams and kb forged pistons. also what do i need to get balanced? hope i dont sound to dumb thanks.
So i can run a 6" or a 5.7 just have to have the right pin height piston? is there any advantage disadvantage? I think in the unforeseen future I may or may not build a 383 so that would be a reason to run a 6” rod right? Thanks for your help guys
Longer rods increase TDC dwell time, which IIRC makes the engine a little more detonation-resistant. It also improves rod/crank/piston geometry, which can reduce the wear rate on the cylinder walls. Handles high RPM better too.
Exactly.....now as for with a stock 350 I don't think you'll get too much out of it, but with a longer throw crank you'll not only pick up cubes, you'll get some tq and power
