6" 5.7" rods 350ci
Old Jun 18, 2009 | 07:48 PM
paxtonLT1's Avatar
6" 5.7" rods 350ci
can i run 6 or 5.7" rods with stock crank?? i see theres 2 pistons with difernt pin hights. im geting eagle h-beams and kb forged pistons. also what do i need to get balanced? hope i dont sound to dumb thanks.
Old Jun 18, 2009 | 08:56 PM
crash4cyl's Avatar
you can run a 6" rod with the stock crank. As for balancing, you need the rank rods and pistons....Talk to the machine shop and see if they want the bearings as well, some shops may.....
Old Jun 18, 2009 | 09:55 PM
paxtonLT1's Avatar
So i can run a 6" or a 5.7 just have to have the right pin height piston? is there any advantage disadvantage? I think in the unforeseen future I may or may not build a 383 so that would be a reason to run a 6” rod right? Thanks for your help guys
Old Jun 18, 2009 | 10:07 PM
1989TransAm's Avatar
Yep, in fact I will be running a 6.125" rod in my new motor.
Old Jun 18, 2009 | 10:34 PM
paxtonLT1's Avatar
and still only 350 ci? wow what the anvantage to a longer rod? shorter piston? lighter?
Old Jun 19, 2009 | 03:29 AM
Air-Adam's Avatar
Longer rods increase TDC dwell time, which IIRC makes the engine a little more detonation-resistant. It also improves rod/crank/piston geometry, which can reduce the wear rate on the cylinder walls. Handles high RPM better too.
Old Jun 19, 2009 | 07:45 AM
crash4cyl's Avatar
Exactly.....now as for with a stock 350 I don't think you'll get too much out of it, but with a longer throw crank you'll not only pick up cubes, you'll get some tq and power
Old Jun 19, 2009 | 09:02 PM
paxtonLT1's Avatar
wow ok sounds good 6" rod it will be thanks for your help guys hay what about rings anything special? im pushin about 6psi
Old Jun 20, 2009 | 12:06 AM
rskrause's Avatar
Moderator
The differences between them will be minimal.
Rich
Old Jun 23, 2009 | 08:04 PM
marshall93z's Avatar
Because cubes = torque and power.
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
karpetcm
Sep 15, 2015 11:07 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
